주요 콘텐츠로 건너뛰기
Zoll Impact Uni-Vent 731 Battery Compartment Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement, Battery Compartment Kit: 1 단계, 이미지 1/1
    • Remove the battery compartment cover by unscrewing the (4) Phillips 6-32 X 5/16 screws. This is indicated in red with the number 1.
    • Page 25.
  2. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 2 단계, 이미지 1/2 Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 2 단계, 이미지 2/2
    • Remove the battery by unscrewing the (4)Phillips 6-32 X 2 ¼ screws and detaching the plug from its locking latch. This is indicated in the second picture in blue with the number 2.
    • Page 25.
  3. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 3 단계, 이미지 1/1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
    • Page 25.
  4. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 4 단계, 이미지 1/1
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) Phillips 6-32 X 5/16 screws provided.
    • Page 25.
  5. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 5 단계, 이미지 1/1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) Phillips 6-32 X 2 ¼ screws. This is indicated in blue with the number 5.
    • Page 25.
  6. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 6 단계, 이미지 1/1
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X5/16 screws. This is indicated in red with the number 6.
    • Page 25.
  7. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: 7 단계, 이미지 1/1
    • Perform HiPot Testing then perform Functional Test using the RCS to verify the replacement is working properly.
    • Page 25.
결론
Michaela Fromm
회원 가입일: 05/04/20
150 평판
안내서 1개 작성함
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Cal Poly, Team S1-G5, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 310
