주요 콘텐츠로 건너뛰기
Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement, SPM Vent Kit: 1 단계, 이미지 1/1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake.
  2. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 2 단계, 이미지 1/2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 2 단계, 이미지 2/2
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator.
  3. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 3 단계, 이미지 1/2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 3 단계, 이미지 2/2
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”.
  4. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 4 단계, 이미지 1/1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module.
  5. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 5 단계, 이미지 1/3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 5 단계, 이미지 2/3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 5 단계, 이미지 3/3
    • Remove the battery compartment cover by unscrewing the (4) 6-32 X 5/16 screws.
  6. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 6 단계, 이미지 1/1
    • Remove the battery by unscrewing the (4) 6-32 X 2 ¼ screws and detaching the plug from its lockinglatch.
  7. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 7 단계, 이미지 1/1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
  8. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 8 단계, 이미지 1/1
    • Loosen and remove the (2) 4-40 X 1 ¼ Screws and nylon spacers supporting the Power Input assembly unto the chassis
  9. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 9 단계, 이미지 1/1
    • Loosen and remove the (2) 6-32 X ¼ screws holding the chassis to the dovetail mounting bracket and remove the SPO2 insulator. Loosen and remove the (2) 8-32 X ¼ screws holding the chassis to the vent module
  10. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 10 단계, 이미지 1/1
    • Insert screwdriver through the holes on the chassis to loosen and remove the (2) 6-32 x 5/16 screws holding the chassis to the vent module.
  11. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 11 단계, 이미지 1/1
    • Lift the damaged chassis from the ventilator module.
  12. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 12 단계, 이미지 1/1
    • Disconnect the Power Input cable from the PIM PCB by pressing on the locking latch and pulling the cable straight up from the connector.
  13. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 13 단계, 이미지 1/1
    • Remove the PIM PCB by loosening the (5) 4-40 X 5/16 screws.
  14. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 14 단계, 이미지 1/1
    • Remove the Dovetail stabilizer bracket by loosening and removing the (2) 6-32 x ¼ and the (2) 4-40 X ¼ screws.
  15. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 15 단계, 이미지 1/1
    • Install the dovetail stabilizer bracket ontothe new SPM assembly by tightening the (2) 6-32 X ¼ and (2) 4-40 X ¼ screws.
  16. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 16 단계, 이미지 1/1
    • Secure the PIM Board to the new SPM with the (5) 4-40 x 5/16 screws.
  17. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 17 단계, 이미지 1/1
    • Secure the chassis to the vent module using the (2) 6-32 X ¼ screws with SPO2 insulator, the (2) 8-32 X ¼ and the (2) 6-32 x 5/16 screws.
  18. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 18 단계, 이미지 1/1
    • Secure the Power Input assembly to the Chassis using the (2) spacers and (2) 4-40 X 1 ¼ screws. Do not over-tighten the screws.
  19. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 19 단계, 이미지 1/2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 19 단계, 이미지 2/2
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) 6-32 X 5/16 screws provided
  20. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 20 단계, 이미지 1/1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) 6-32 X 2 ¼ screws.
  21. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 21 단계, 이미지 1/3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 21 단계, 이미지 2/3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 21 단계, 이미지 3/3
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X 5/16 screws.
  22. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 22 단계, 이미지 1/1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position.
  23. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 23 단계, 이미지 1/1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws.
  24. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 24 단계, 이미지 1/2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 24 단계, 이미지 2/2
    • Tighten the (4) 8-32 X 3 screws on the outer air intake.
  25. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: 25 단계, 이미지 1/1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Drury
회원 가입일: 05/04/20
391 평판
안내서 1개 작성함
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Cal Poly, Team S1-G5, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G5
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi
What is the service passcode to reset the PM clock?
fayezhmc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 343
