주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zoom H1 Handy Recorder Battery Terminal Replacement
필요한 것
    1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: 1 단계, 이미지 1개 중 1개
      • Place the device so the display is down.
      댓글 쓰기
    2. Zoom H1 Handy Recorder Battery Terminal Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery cover, pressing down on the tabs and sliding.
      댓글 쓰기
    3. Zoom H1 Handy Recorder Battery Terminal Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
      댓글 쓰기
    4. Zoom H1 Handy Recorder Battery Terminal Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully pry up the top end of the back cover using one finger
      댓글 쓰기
    5. Zoom H1 Handy Recorder Battery Terminal Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
      댓글 쓰기
    6. Zoom H1 Handy Recorder Battery Terminal Replacement: 6 단계, 이미지 1개 중 1개
      • De-solder at terminal point one.
      댓글 쓰기
    7. Zoom H1 Handy Recorder Battery Terminal Replacement: 7 단계, 이미지 1개 중 1개
      • De-solder at the second terminal point.
      댓글 쓰기
    8. Zoom H1 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 2개 중 1개 Zoom H1 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the faulty terminals
      댓글 쓰기
    9. Zoom H1 Handy Recorder Battery Terminal Replacement: 9 단계, 이미지 1개 중 1개
      • Place new lead in at point one and re-solder at the point.
      댓글 쓰기
    10. Zoom H1 Handy Recorder Battery Terminal Replacement: 10 단계, 이미지 1개 중 1개
      • Place second lead at point 2 and re-solder.
      댓글 쓰기
결론
To Re-construct device, perform these steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Alex
회원 가입일: 10/28/13
809 평판
안내서 5개를 작성함
7가이드 댓글
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - 답글 공유
Mine has third screw under the serial-number sticker.
halluciana - 답글 공유
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - 답글 공유
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - 답글 공유
Same problem, without any reason it is dead
eevilcute - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 49
전체 시간: 7,491
