주요 콘텐츠로 건너뛰기
Zoom H1 Handy Recorder Battery Terminal Replacement
필요한 것
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: 1 단계, 이미지 1/1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: 3 단계, 이미지 1/1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: 4 단계, 이미지 1/1
    • Carefully pry up the top end of the back cover using one finger
    There is a third screw right next to the serial number sticker on mine.
    Ricardo Teixeira - 답글
    Same comment here, 3rd screw not to be forgotten.
    yves debacker - 답글
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: 5 단계, 이미지 1/1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: 6 단계, 이미지 1/1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: 7 단계, 이미지 1/1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 1/2 Zoom H1 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 2/2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: 9 단계, 이미지 1/1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: 10 단계, 이미지 1/1
    • Place second lead at point 2 and re-solder.
결론
To Re-construct device, perform these steps in reverse order.
Alex
회원 가입일: 10/28/13
809 평판
안내서 5개 작성하였습니다
댓글 7개
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - 답글
Mine has third screw under the serial-number sticker.
halluciana - 답글
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - 답글
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - 답글
Same problem, without any reason it is dead
eevilcute -
Where can i find the replacement battery terminals?
krissie_prime - 답글
My zoom h1 just dead exactly after 2 years with no reason. It doesn’t turn on. The battery terminals are in good condition. Any ideas?
btw yes there is a third screw under the serial-number sticker.
Paco Raya Morales - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 30
전체 시간: 6,382
