주요 콘텐츠로 건너뛰기
Zoom H1 Handy Recorder Speaker Replacement
필요한 것
  1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Turn the device over with its display down.
  2. Zoom H1 Handy Recorder Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Speaker Replacement: 3 단계, 이미지 1/1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. Zoom H1 Handy Recorder Speaker Replacement: 4 단계, 이미지 1/1
    • Carefully pry up the top end of the back cover using one finger.
  5. Zoom H1 Handy Recorder Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Speaker Replacement: 6 단계, 이미지 1/1
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  7. Zoom H1 Handy Recorder Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  8. Zoom H1 Handy Recorder Speaker Replacement: 8 단계, 이미지 1/1
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
결론
Alex
회원 가입일: 10/28/13
809 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 1,696
