소개
Welcome to the Zoom H1 Handy Recorder guide to replace the USB port. It will happen at times that the USB port corrodes, suffers damage, or ages in quality, making the recorder not read devices properly or not connect at all. This guide will provide step-by-step instructions to help you replace the USB port. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. Luckily, iFixit has a Wiki on all of the above! Click here to access the Wiki. Now go and make your Zoom H1 Handy Recorder work like new again!
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
This is awesome. Do you know if I can switch the port for USB-C?
Regan Ryan - 답글
What USB Port do i need to get?
