주요 콘텐츠로 건너뛰기
Zoom H6 Handy Recorder Audio Input Jack Replacement
필요한 것
  1. Zoom H6 Handy Recorder Audio Input Jack Replacement, Case: 1 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Case: 1 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Audio Input Jack Replacement: 2 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 2 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Audio Input Jack Replacement: 3 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 3 단계, 이미지 2개 중 2개
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Audio Input Jack Replacement: 4 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 4 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 4 단계, 이미지 3개 중 3개
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Audio Input Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
  6. Zoom H6 Handy Recorder Audio Input Jack Replacement: 6 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 6 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 6 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
    • Set the button board aside.
  7. Zoom H6 Handy Recorder Audio Input Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew four (PH #1), 8mm screws from the motherboard.
  8. Zoom H6 Handy Recorder Audio Input Jack Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect wire from motherboard using tweezers.
    • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
  9. Zoom H6 Handy Recorder Audio Input Jack Replacement: 9 단계, 이미지 1개 중 1개
    • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
  10. Zoom H6 Handy Recorder Audio Input Jack Replacement: 10 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 10 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 10 단계, 이미지 3개 중 3개
    • Gently remove three ribbon connectors from the device.
    • The first is connected to the mic connector.
    • The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
    • It's best to use tweezers to remove the two ribbon connectors behind the display.
    • Avoid touching anything but the ribbon connectors with the metal tweezers.
  11. Zoom H6 Handy Recorder Audio Input Jack Replacement: 11 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 11 단계, 이미지 2개 중 2개
    • Gently lift the motherboard from the base of the device and set aside.
  12. Zoom H6 Handy Recorder Audio Input Jack Replacement, Audio Input Jack: 12 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Audio Input Jack: 12 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement, Audio Input Jack: 12 단계, 이미지 3개 중 3개
    • Lift the mic connector out of the base of the device.
  13. Zoom H6 Handy Recorder Audio Input Jack Replacement: 13 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 13 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Audio Input Jack Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the audio input jack to remove it.
    • Repeat with the other input jack.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Rachel Calder
회원 가입일: 02/14/18
1,261 평판
안내서 5개를 작성함
USF Tampa, Team S5-G2, Eyestone Spring 2018 USF Tampa, Team S5-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G2
4 회원들
안내서 10개를 작성함
1가이드 댓글
Zoom h6]
Good night ... I have a wheezing problem at the xlr entrances. Could it be the preams? Even without phanton power or alloy microphones he modulates and records a very loud hiss. Are the preams on the motherboard or are they in a separate module?
Nando - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 38
전체 시간: 2,939
