주요 콘텐츠로 건너뛰기
Zoom H6 Handy Recorder Battery Terminal Replacement
필요한 것
  1. Zoom H6 Handy Recorder Battery Terminal Replacement, Battery Terminal: 1 단계, 이미지 1개 중 1개
    • Place device on table facing down.
    • Remove the battery cover, with index finger press protruding tab towards "OPEN".
  2. Zoom H6 Handy Recorder Battery Terminal Replacement: 2 단계, 이미지 1개 중 1개
    • If batteries are present, remove them in order to reveal the terminals at the bottom of the device.
  3. Zoom H6 Handy Recorder Battery Terminal Replacement: 3 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 3 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 3 단계, 이미지 3개 중 3개
    • With the flat end of the black plastic spudger, pry the terminal away from the case.
    • Use the small blue plastic opening tool to lift the terminal out of the device. Repeat for the adjacent terminal.
    • When lifting the terminal out, the metal wire of the terminal must move past the plastic protrusion that keeps the battery terminal in place.
  4. Zoom H6 Handy Recorder Battery Terminal Replacement: 4 단계, 이미지 1개 중 1개
    • Remove four rubber feet using fingernails to access the four screws underneath.
  5. Zoom H6 Handy Recorder Battery Terminal Replacement: 5 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 5 단계, 이미지 2개 중 2개
    • For the terminals directly connected to the motherboard, unscrew eight (PH #1), 9 mm screws (two located on the top back side, two in the center of back side of device right above the battery cover, and four under the rubber feet).
    • An electronics screwdriver narrow enough to fit in hole (3.5mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the two screws in the center of back side of the device.
  6. Zoom H6 Handy Recorder Battery Terminal Replacement: 6 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 6 단계, 이미지 2개 중 2개
    • Place device face up and remove the four knobs using the flat end of the plastic opening tool.
  7. Zoom H6 Handy Recorder Battery Terminal Replacement: 7 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 7 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully lift up the top of the device and gently set aside.
  8. Zoom H6 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew three (PH #1), 7mm screws from the button board near the display and gently flip over.
  9. Zoom H6 Handy Recorder Battery Terminal Replacement: 9 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 9 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 9 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
    • Set the button board aside.
  10. Zoom H6 Handy Recorder Battery Terminal Replacement: 10 단계, 이미지 1개 중 1개
    • Unscrew four (PH #1), 8mm screws from the motherboard.
  11. Zoom H6 Handy Recorder Battery Terminal Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect wire from motherboard using tweezers.
    • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
  12. Zoom H6 Handy Recorder Battery Terminal Replacement: 12 단계, 이미지 1개 중 1개
    • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
  13. Zoom H6 Handy Recorder Battery Terminal Replacement: 13 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 13 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 13 단계, 이미지 3개 중 3개
    • Gently remove three ribbon connectors from the base of the device. One is connected to the mic connector, the other two are on the top of the device next to the "LINE OUT" plug-in (directly behind the device display screen).
    • Use tweezers to remove the two ribbon connectors behind the display screen because it is difficult to remove them only using hands.
    • Avoid touching anything but the ribbon connectors with the metal tweezers.
  14. Zoom H6 Handy Recorder Battery Terminal Replacement: 14 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 14 단계, 이미지 2개 중 2개
    • Gently lift off motherboard from the base of the device.
  15. Zoom H6 Handy Recorder Battery Terminal Replacement: 15 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 15 단계, 이미지 2개 중 2개
    • Taking care not to damage other components on the motherboard, use a soldering iron to undo the soldering that holds the terminals to the motherboard.
  16. Zoom H6 Handy Recorder Battery Terminal Replacement: 16 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Battery Terminal Replacement: 16 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Battery Terminal Replacement: 16 단계, 이미지 3개 중 3개
    • Flip motherboard over and remove the black tape covering the battery terminal.
    • Replace with new terminal.
    • Resolder the terminals to the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rachel Calder
회원 가입일: 02/14/18
1,261 평판
안내서 5개를 작성함
USF Tampa, Team S5-G2, Eyestone Spring 2018 USF Tampa, Team S5-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G2
4 회원들
안내서 10개를 작성함
2가이드 댓글
Where can I buy the battery compartment please?
Lee - 답글
Where to buy the wire battery contact part?
ericyeong@gmail.com - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 59
전체 시간: 6,210
