주요 콘텐츠로 건너뛰기
Zoom H6 Handy Recorder Case Replacement
필요한 것
  1. Zoom H6 Handy Recorder Case Replacement, Case: 1 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Case Replacement, Case: 1 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Case Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Case Replacement: 2 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Case Replacement: 2 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Case Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Case Replacement: 3 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Case Replacement: 3 단계, 이미지 2개 중 2개
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Case Replacement: 4 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Case Replacement: 4 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Case Replacement: 4 단계, 이미지 3개 중 3개
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rachel Calder
회원 가입일: 02/14/18
1,261 평판
안내서 5개를 작성함
USF Tampa, Team S5-G2, Eyestone Spring 2018 USF Tampa, Team S5-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G2
4 회원들
안내서 10개를 작성함
7가이드 댓글
Where can I get the replacement part. I need to change the casing of my h6 and the power button
Dray - 답글
Did you get to find the replacement casing? Where did you find it?
Jason Irving -
I need a case replacement, too. There is so much broken, hardly to fix with glue …
anything?
Michael Gasperl - 답글
Has anybody found a source for Zoom parts? I would sure like to fix my UAC-8, but parts don’t seem to be available anywhere. It is kind of frustrating, the fix would be easy as heck, but not without parts.
Tim Andre - 답글
contact your nearest dealer listed on the zoom website to buy a replacement set. They shipped me one after the cover finish turned ‘sticky’ and the battery plate lock mechanism broke off due to the plastic going bad. this can happen i.e. after you leave it the sun for too long, which happened to me. this tutorial doesn’t cover the bottom case which is more involving with all the electronics.
veto88 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 78
전체 시간: 6,087
