주요 콘텐츠로 건너뛰기
Zoom H6 Handy Recorder Screen Replacement
필요한 것
  1. Zoom H6 Handy Recorder Screen Replacement, Case: 1 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement, Case: 1 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Screen Replacement: 2 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 2 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Screen Replacement: 3 단계, 이미지 2개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 3 단계, 이미지 2개 중 2개
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Screen Replacement: 4 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 4 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement: 4 단계, 이미지 3개 중 3개
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Screen Replacement, Screen: 5 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement, Screen: 5 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement, Screen: 5 단계, 이미지 3개 중 3개
    • Unscrew three (PH #1), 7 mm screws (two on right side of display and one on the bottom left).
  6. Zoom H6 Handy Recorder Screen Replacement: 6 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 6 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the button board gently to reveal the ribbon connector.
  7. Zoom H6 Handy Recorder Screen Replacement: 7 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 7 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device .
    • Set the button board aside.
  8. Zoom H6 Handy Recorder Screen Replacement: 8 단계, 이미지 3개 중 1개 Zoom H6 Handy Recorder Screen Replacement: 8 단계, 이미지 3개 중 2개 Zoom H6 Handy Recorder Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the screen from the the backing.
    • Replace the screen.
    • Make sure to not touch the screen directly as it will leave smudges.
    • If need be, the ribbon for the screen could also be replaced during this step.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
William D'Arrigo
회원 가입일: 02/14/18
281 평판
안내서 2개를 작성함
USF Tampa, Team S5-G2, Eyestone Spring 2018 USF Tampa, Team S5-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G2
4 회원들
안내서 10개를 작성함
27가이드 댓글
Hello.
I-m so glad to find this tutorial.
I just have one question, do you know where can i get a LCD screen for my zoom H6. I live in France, i’ve been looking for it on the web but nothing. Thankyou for your help.
pernimatic - 답글
Hey friend, check bellow.
Hadrien -
Hi, I have the same question, where can I get the display? in the zoom support they do not respond. Thanks
Jonathan Race - 답글
Hi guys, same problem. I just found this, could it be this screen ? http://www.hktdc.com/suppliers-products/...
Hadrien - 답글
Hi guys, I found my H6 screen here : https://shop.audiotronic.fr/fr/ The team is very nice and helpful, don’t hesitate to call them.
Hadrien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 155
지난 30일: 383
전체 시간: 11,236
