주요 콘텐츠로 건너뛰기
Zoom Q3HD Handy Video Recorder Lens Cleaning
필요한 것
  1. Zoom Q3HD Handy Video Recorder Lens Cleaning, Zoom Q3HD Handy Video Recorder Lens Cleaning: 1 단계, 이미지 1/1
    • Remove the two screws from the bottom of the device.
    • Make sure to put your screws in a safe place.
  2. Zoom Q3HD Handy Video Recorder Lens Cleaning: 2 단계, 이미지 1/1
    • Flip the device over and remove the four screws bordering the grate of the device.
  3. Zoom Q3HD Handy Video Recorder Lens Cleaning: 3 단계, 이미지 1/1
    • On the front of the device, slide the battery compartment cover off by pushing inward and sliding downward.
  4. Zoom Q3HD Handy Video Recorder Lens Cleaning: 4 단계, 이미지 1/1
    • Remove the two screws from the lip of the battery compartment.
  5. Zoom Q3HD Handy Video Recorder Lens Cleaning: 5 단계, 이미지 1/1
    • Remove the final screw from the bed of the battery compartment.
  6. Zoom Q3HD Handy Video Recorder Lens Cleaning: 6 단계, 이미지 1/1
    • WARNING: Pieces may become loose when you separate the device in half!
    • Run the pry tool along the edges of the device to begin separating the device in two halves.
  7. Zoom Q3HD Handy Video Recorder Lens Cleaning: 7 단계, 이미지 1/2 Zoom Q3HD Handy Video Recorder Lens Cleaning: 7 단계, 이미지 2/2
    • REMINDER: Pieces may become loose when you separate the device in half!
    • Apply upward pressure to fully separate the device into two halves.
  8. Zoom Q3HD Handy Video Recorder Lens Cleaning: 8 단계, 이미지 1/1
    • WARNING: If you’re not careful with keeping the screen close to the board, you will rip off the ribbon attaching the screen to the circuit board.
    • Lift display screen keeping the top half close to the board.
  9. Zoom Q3HD Handy Video Recorder Lens Cleaning: 9 단계, 이미지 1/1
    • Gently flip the black clip up attaching the ribbon of the screen to the circuit board.
  10. Zoom Q3HD Handy Video Recorder Lens Cleaning: 10 단계, 이미지 1/1
    • Gently slide the ribbon from the circuit board, removing the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Grace Bently
회원 가입일: 10/13/14
4 평판
안내서 1개 작성함
Ohio State, Team 1-1, Mccook Fall 2014 Ohio State, Team 1-1, Mccook Fall 2014 회원
OSU-MCCOOK-F14S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 3개
My zoom q3HD only have the red light turned on when powering up. No display at all. What is happening? How can I claim warranty? I didn't use the device more than a year. Help me
stancalvin - 답글
This is not comlete, leaves you half way through, would be great if you could finish this, thank you.
smoldas.l - 답글
Yes it would be good to see it finished. I am half way through taking mine apart to clean the lens amd i don't know if i should proceed or not. Its the 2nd time the lens has fogged up. My 2nd q3hd.
steven kemsley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,975
