주요 콘텐츠로 건너뛰기
Zoombak Personal GPS Locator Battery Replacement
필요한 것
  1. Zoombak Personal GPS Locator Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Zoombak Personal GPS device
  2. Zoombak Personal GPS Locator Battery Replacement: 2 단계, 이미지 1/1
    • Backside has four rubber plugs. Remove them and find the Phillips head screws.
  3. Zoombak Personal GPS Locator Battery Replacement: 3 단계, 이미지 1/1
    • Use a small tip flat blade screw driver to remove the rubber plugs.
  4. Zoombak Personal GPS Locator Battery Replacement: 4 단계, 이미지 1/1
    • Plugs removed
  5. Zoombak Personal GPS Locator Battery Replacement: 5 단계, 이미지 1/1
    • Rubber plugs
  6. Zoombak Personal GPS Locator Battery Replacement: 6 단계, 이미지 1/1
    • Remove the bottom cover.
  7. Zoombak Personal GPS Locator Battery Replacement: 7 단계, 이미지 1/1
    • Old battery. No numbers just 3.7 volt 890mAh. Very difficult to figure out. I found a Sony Erricson J100, J220, W710, W810, Z300, Z710 battery that fits perfectly.
  8. Zoombak Personal GPS Locator Battery Replacement: 8 단계, 이미지 1/1
    • The old one was swollen from being on the charger for so long.
  9. Zoombak Personal GPS Locator Battery Replacement: 9 단계, 이미지 1/1
    • The case without the battery.
  10. Zoombak Personal GPS Locator Battery Replacement: 10 단계, 이미지 1/1
    • New battery installed.
  11. Zoombak Personal GPS Locator Battery Replacement: 11 단계, 이미지 1/1
    • And turn it back on, and it blinks green! I let it run down and recharged the battery. I get about 3 days use from it now. Good luck!
결론
다른 3명이 해당 안내서를 완성하였습니다.
James
회원 가입일: 10/04/10
113 평판
안내서 1개 작성함
댓글 2개
Excellent guide! Precise step-by-step instructions. The recommended replacement battery was a perfect fit, and works like the original battery. Took about 20 minutes and approx $5.00 for the new battery to do the entire job.
I wish all how-to guides were as well written and easy to follow as this one. Thanks!
j fkmetz - 답글
Zoombak.com is gone. How do I reactivate mine, and get the software that did the tracking back.
Sean Connors - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 4,248
