주요 콘텐츠로 건너뛰기
Zoomer Dino Boomer Back Button Replacement
필요한 것
  1. Zoomer Dino Boomer Back Button Replacement, Back Cover: 1 단계, 이미지 1/1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Back Button Replacement: 2 단계, 이미지 1/2 Zoomer Dino Boomer Back Button Replacement: 2 단계, 이미지 2/2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 1/3 Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 2/3 Zoomer Dino Boomer Back Button Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Back Button Replacement, Back Button: 4 단계, 이미지 1/1
    • Where the button is largest, squeeze the two white tabs together.
  5. Zoomer Dino Boomer Back Button Replacement: 5 단계, 이미지 1/1
    • Push in the white circular piece between these tabs as far as it will go.
  6. Zoomer Dino Boomer Back Button Replacement: 6 단계, 이미지 1/2 Zoomer Dino Boomer Back Button Replacement: 6 단계, 이미지 2/2
    • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
    • Remove the back button.
결론
Lauren Mannix
회원 가입일: 08/29/15
398 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 2,037
