주요 콘텐츠로 건너뛰기
Zoomer Jurassic World Indominus Rex Back Cover Replacement
필요한 것
  1. Zoomer Jurassic World Indominus Rex Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Back Cover Replacement: 2 단계, 이미지 1/2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: 2 단계, 이미지 2/2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Back Cover Replacement: 3 단계, 이미지 1/2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: 3 단계, 이미지 2/2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
결론
Anh Le
회원 가입일: 01/20/16
504 평판
안내서 3개 작성하였습니다
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 416
