주요 콘텐츠로 건너뛰기
Zoomer Jurassic World Indominus Rex Eye LED Replacement
필요한 것
  1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: 1 단계, 이미지 1/2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: 1 단계, 이미지 2/2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: 2 단계, 이미지 1/3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: 2 단계, 이미지 2/3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: 2 단계, 이미지 3/3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: 3 단계, 이미지 1/2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: 3 단계, 이미지 2/2
    • Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
    • Use tweezers to pull the circuit board out of place.
    • Pull directly upward! Be careful not to break the circuit board during removal.
  4. Zoomer Jurassic World Indominus Rex Eye LED Replacement: 4 단계, 이미지 1/1
    • Use a soldering iron to disconnect the four (4) wires from the circuit board.
    • Soldering technique guide from iFixit can be found here.
    • Be careful not to burn yourself or the plastic while soldering!
결론
Luke Selby
회원 가입일: 01/20/16
624 평판
안내서 4개 작성하였습니다
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 345
