주요 콘텐츠로 건너뛰기
Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
필요한 것
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: 1 단계, 이미지 1/2 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: 1 단계, 이미지 2/2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 2 단계, 이미지 1/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 2 단계, 이미지 2/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 2 단계, 이미지 3/3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 3 단계, 이미지 1/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 3 단계, 이미지 2/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: 3 단계, 이미지 3/3
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 4 단계, 이미지 1/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 4 단계, 이미지 2/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 5 단계, 이미지 1/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 5 단계, 이미지 2/3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 5 단계, 이미지 3/3
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: 6 단계, 이미지 1/1
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
결론
Luke Selby
회원 가입일: 01/20/16
636 평판
안내서 4개 작성하였습니다
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 705
