주요 콘텐츠로 건너뛰기
Zoomer Meowzies Chest Senor Replacement
필요한 것
  1. Zoomer Meowzies Chest Senor Replacement, Legs: 1 단계, 이미지 1/3 Zoomer Meowzies Chest Senor Replacement, Legs: 1 단계, 이미지 2/3 Zoomer Meowzies Chest Senor Replacement, Legs: 1 단계, 이미지 3/3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Chest Senor Replacement: 2 단계, 이미지 1/2 Zoomer Meowzies Chest Senor Replacement: 2 단계, 이미지 2/2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Chest Senor Replacement: 3 단계, 이미지 1/3 Zoomer Meowzies Chest Senor Replacement: 3 단계, 이미지 2/3 Zoomer Meowzies Chest Senor Replacement: 3 단계, 이미지 3/3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Chest Senor Replacement, Chest Senor: 4 단계, 이미지 1/3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: 4 단계, 이미지 2/3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: 4 단계, 이미지 3/3
    • Carefully pry the ribbon cable from the connector.
    • Though we find it easier to use our fingers, the pry-tools may be useful.
  5. Zoomer Meowzies Chest Senor Replacement: 5 단계, 이미지 1/3 Zoomer Meowzies Chest Senor Replacement: 5 단계, 이미지 2/3 Zoomer Meowzies Chest Senor Replacement: 5 단계, 이미지 3/3
    • For easier access to the sensor, tilt and pull the sensor away from the body.
  6. Zoomer Meowzies Chest Senor Replacement: 6 단계, 이미지 1/3 Zoomer Meowzies Chest Senor Replacement: 6 단계, 이미지 2/3 Zoomer Meowzies Chest Senor Replacement: 6 단계, 이미지 3/3
    • To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
    • The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
  7. Zoomer Meowzies Chest Senor Replacement: 7 단계, 이미지 1/2 Zoomer Meowzies Chest Senor Replacement: 7 단계, 이미지 2/2
    • Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
    • The sensor should be completely detachable now.
결론
Mitchell Gentry
회원 가입일: 02/14/18
675 평판
안내서 6개 작성하였습니다
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G2
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 483
