소개
This guide will go over how to remove and replace a faulty speaker of a Zoomer Meowzies.
필요한 것
On the bottom half of the device's head, locate the two screws on each side of the speaker. Using the Phillips #1 driver remove the two 7mm screws.
Remove the black brace holding the speaker by gently pulling on it. The speaker will likely fall out after lifting the black brace.
다른 한 분이 해당 안내서를 완성하였습니다.
