주요 콘텐츠로 건너뛰기
Zoomer Meowzies Wheels Replacement
필요한 것
  1. Zoomer Meowzies Wheels Replacement, Legs: 1 단계, 이미지 1/3 Zoomer Meowzies Wheels Replacement, Legs: 1 단계, 이미지 2/3 Zoomer Meowzies Wheels Replacement, Legs: 1 단계, 이미지 3/3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Wheels Replacement: 2 단계, 이미지 1/2 Zoomer Meowzies Wheels Replacement: 2 단계, 이미지 2/2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Wheels Replacement: 3 단계, 이미지 1/3 Zoomer Meowzies Wheels Replacement: 3 단계, 이미지 2/3 Zoomer Meowzies Wheels Replacement: 3 단계, 이미지 3/3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Wheels Replacement, Wheels: 4 단계, 이미지 1/1
    • Turn the Zoomer Meowzies leg to its side.
    • Using the Triangle driver remove the two bottom 7 mm screws.
  5. Zoomer Meowzies Wheels Replacement: 5 단계, 이미지 1/1
    • Hold both sides of the leg and gently pull apart.
    • If pulled apart too forcefully the rest of the leg may sustain damage. Caution is advised.
  6. Zoomer Meowzies Wheels Replacement: 6 단계, 이미지 1/2 Zoomer Meowzies Wheels Replacement: 6 단계, 이미지 2/2
    • Wheel should now be exposed. Pull wheel up and away from the rest of the leg to remove. Replace with new wheel if necessary.
결론
Muataz Alahmadi
회원 가입일: 02/14/18
193 평판
안내서 2개 작성하였습니다
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G2
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 326
