주요 콘텐츠로 건너뛰기
Zoomer Show Pony Leg Spring Replacement
필요한 것
  1. Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 1 단계, 이미지 1/3 Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 1 단계, 이미지 2/3 Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 1 단계, 이미지 3/3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Leg Spring Replacement: 2 단계, 이미지 1/3 Zoomer Show Pony Leg Spring Replacement: 2 단계, 이미지 2/3 Zoomer Show Pony Leg Spring Replacement: 2 단계, 이미지 3/3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Zoomer Show Pony Leg Spring Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. Zoomer Show Pony Leg Spring Replacement: 4 단계, 이미지 1/2 Zoomer Show Pony Leg Spring Replacement: 4 단계, 이미지 2/2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
  5. Zoomer Show Pony Leg Spring Replacement, Leg Spring: 5 단계, 이미지 1/3 Zoomer Show Pony Leg Spring Replacement, Leg Spring: 5 단계, 이미지 2/3 Zoomer Show Pony Leg Spring Replacement, Leg Spring: 5 단계, 이미지 3/3
    • Remove all five triangular screws located on the backside of the leg.
    • Remove the Phillips head screw holding the white leg bracket.
    • The white bracket MUST be re-connected in the same orientation. Make sure to note which side is up and down. The part looks symmetric to the blind eye but it is not.
    • Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
  6. Zoomer Show Pony Leg Spring Replacement: 6 단계, 이미지 1/3 Zoomer Show Pony Leg Spring Replacement: 6 단계, 이미지 2/3 Zoomer Show Pony Leg Spring Replacement: 6 단계, 이미지 3/3
    • Lift up on the plastic housing located on the upper portion of the leg (where it connects to the body).
    • Carefully separate the plastic housing at the base of the leg.
    • Remove slowly, there are small components attached to the motor that could become loose and/or missing.
  7. Zoomer Show Pony Leg Spring Replacement: 7 단계, 이미지 1/1
    • The spring will be exposed as shown. Remove the broken or damaged spring and replace it with a new one.
    • Spring must be in the "loaded position" when reassembling (there should be some resistance).
결론
James
회원 가입일: 01/25/18
97 평판
안내서 1개 작성함
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 345
