주요 콘텐츠로 건너뛰기
Zoomer Show Pony Power and Volume Switch Replacement
필요한 것
  1. Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: 1 단계, 이미지 1/3 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: 1 단계, 이미지 2/3 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: 1 단계, 이미지 3/3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Power and Volume Switch Replacement: 2 단계, 이미지 1/3 Zoomer Show Pony Power and Volume Switch Replacement: 2 단계, 이미지 2/3 Zoomer Show Pony Power and Volume Switch Replacement: 2 단계, 이미지 3/3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
결론
Matthew Sutton
회원 가입일: 01/25/18
278 평판
안내서 2개 작성하였습니다
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 715
