주요 콘텐츠로 건너뛰기
Zoomer Show Pony Sensor Replacement
필요한 것
  1. Zoomer Show Pony Sensor Replacement, Sensor: 1 단계, 이미지 1/3 Zoomer Show Pony Sensor Replacement, Sensor: 1 단계, 이미지 2/3 Zoomer Show Pony Sensor Replacement, Sensor: 1 단계, 이미지 3/3
    • Flip over your pony and find the screws marked in red.
    • Remove these screws with a 3.0 Triangle screw bit. Don't worry about keeping them seperated because they are all the same size.
    • When the screws are removed the head and rear legs should be removable. Be careful to not pull everything apart to much because the head and legs are all connected to the motherboard.
  2. Zoomer Show Pony Sensor Replacement: 2 단계, 이미지 1/3 Zoomer Show Pony Sensor Replacement: 2 단계, 이미지 2/3 Zoomer Show Pony Sensor Replacement: 2 단계, 이미지 3/3
    • Remove the wires connecting the head and leg sections. We will disconnect all of the wire connections in this step and they will need to be re-connected at the end, so be careful when disconnecting.
    • Now that the wires have been disconnected, the head and back legs should be free to place aside
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  3. Zoomer Show Pony Sensor Replacement: 3 단계, 이미지 1/3 Zoomer Show Pony Sensor Replacement: 3 단계, 이미지 2/3 Zoomer Show Pony Sensor Replacement: 3 단계, 이미지 3/3
    • Take out the two clips keeping the motherboard in place but applying upwards pressure on them.
    • Remove the motherboard and replace. The sensors are soldered on to the motherboard so the whole board must be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cedric Bossa
회원 가입일: 10/02/17
118 평판
안내서 1개 작성함
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 697
