주요 콘텐츠로 건너뛰기
Zoomer Show Pony Speaker Replacement
필요한 것
  1. Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 1 단계, 이미지 1/3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 1 단계, 이미지 2/3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 1 단계, 이미지 3/3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Speaker Replacement: 2 단계, 이미지 1/3 Zoomer Show Pony Speaker Replacement: 2 단계, 이미지 2/3 Zoomer Show Pony Speaker Replacement: 2 단계, 이미지 3/3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Zoomer Show Pony Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. Zoomer Show Pony Speaker Replacement: 4 단계, 이미지 1/2 Zoomer Show Pony Speaker Replacement: 4 단계, 이미지 2/2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
결론
Matthew Sutton
회원 가입일: 01/25/18
278 평판
안내서 2개 작성하였습니다
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 270
