소개
Zotac's bare-bones machines come without Internal Storage or RAM. Here's how to install the Internal Storage.
필요한 것
Zotac uses thumb screws to secure the case. No tools required!
After you remove the thumb screws, just slide the bottom cover away from you and lift it away.
The EN970 has three hard drive connectors: 2 2.5" bays and 1 M.2 bay.
There are thumb screws for the 2.5" drives that secure plastic caddies that snap onto your drive
The M.2 drive requires a phillips screwdriver for installation. Your ZBOX should have two screws inserted in two of the three pegs.
Remove the screws, insert your drive and use one screw to secure it. Be sure not to over-tighten.
다른 9명이 해당 안내서를 완성하였습니다.
