주요 콘텐츠로 건너뛰기
Zte Avail 2 Display Replacement
필요한 것
  1. Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 1/3 Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 2/3 Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 3/3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: 2 단계, 이미지 1/2 Zte Avail 2 Display Replacement: 2 단계, 이미지 2/2
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: 3 단계, 이미지 1/1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: 4 단계, 이미지 1/2 Zte Avail 2 Display Replacement: 4 단계, 이미지 2/2
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: 5 단계, 이미지 1/2 Zte Avail 2 Display Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: 6 단계, 이미지 1/1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: 7 단계, 이미지 1/1
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: 8 단계, 이미지 1/1
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: 9 단계, 이미지 1/1
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
결론
다른 5명이 해당 안내서를 완성하였습니다.
dunnluke
회원 가입일: 09/22/15
237 평판
안내서 1개 작성함
University of Alabama, Team 1-6, Sydow campbell Fall 2015 University of Alabama, Team 1-6, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G6
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 967
