주요 콘텐츠로 건너뛰기
Zte Avail 2 Display Replacement
필요한 것
  1. Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Zte Avail 2 Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: 2 단계, 이미지 2개 중 1개 Zte Avail 2 Display Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: 3 단계, 이미지 1개 중 1개
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: 4 단계, 이미지 2개 중 1개 Zte Avail 2 Display Replacement: 4 단계, 이미지 2개 중 2개
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: 5 단계, 이미지 2개 중 1개 Zte Avail 2 Display Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: 6 단계, 이미지 1개 중 1개
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: 7 단계, 이미지 1개 중 1개
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: 8 단계, 이미지 1개 중 1개
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: 9 단계, 이미지 1개 중 1개
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
dunnluke
회원 가입일: 09/22/15
237 평판
안내서 1개를 작성함
1가이드 댓글
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 1,164
