주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Microsoft Zune 80 수리는 저희 서비스 설명서를 사용하십시오.
  1. Zune 80 GB Teardown, Zune 80 GB Teardown: 1 단계, 이미지 1/1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap located on top of the device.
  2. Zune 80 GB Teardown: 2 단계, 이미지 1/1
    • There are two T4 screws under the cap. Remove both screws with a T4 screwdriver.
    • WARNING: Be careful when removing the screws since they can strip very easily.
  3. Zune 80 GB Teardown: 3 단계, 이미지 1/2 Zune 80 GB Teardown: 3 단계, 이미지 2/2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are five clips on each side and two on the bottom.
    • WARNING: Be careful not to press the tools in too far because there are exposed cables right inside the edge of the device.
  4. Zune 80 GB Teardown: 4 단계, 이미지 1/2 Zune 80 GB Teardown: 4 단계, 이미지 2/2
    • Remove the silver tape from the bottom center and the top right of the device. This allows access to the hard drive and the battery.
  5. Zune 80 GB Teardown: 5 단계, 이미지 1/3 Zune 80 GB Teardown: 5 단계, 이미지 2/3 Zune 80 GB Teardown: 5 단계, 이미지 3/3
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive.
    • Gently push towards the bottom of the device on the black bar until you hear a click sound. It is now disengaged from the hard drive.
    • If the cable does not come off easily, the black bar has not been un-clicked.
    • Now, gently pull the orange hard drive cable to remove it from the hard drive cable.
    • Lift the hard drive out of the device.
  6. Zune 80 GB Teardown: 6 단계, 이미지 1/2 Zune 80 GB Teardown: 6 단계, 이미지 2/2
    • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  7. Zune 80 GB Teardown: 7 단계, 이미지 1/1
    • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  8. Zune 80 GB Teardown: 8 단계, 이미지 1/3 Zune 80 GB Teardown: 8 단계, 이미지 2/3 Zune 80 GB Teardown: 8 단계, 이미지 3/3
    • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
    • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  9. Zune 80 GB Teardown: 9 단계, 이미지 1/1
    • The orange audio board cable is clipped in with a small black bar, like the hard drive cable.
    • Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when it disengages.
    • If the cable does not come off easily, the black bar has not been unclicked.
  10. Zune 80 GB Teardown: 10 단계, 이미지 1/1
    • Flip the black bar to unclip the left side of the hard drive cable. You may now remove the hard drive cable.
  11. Zune 80 GB Teardown: 11 단계, 이미지 1/2 Zune 80 GB Teardown: 11 단계, 이미지 2/2
    • Remove the two T4 screws that hold the charging port on the bottom of the device.
    • Remove the charging port.
  12. Zune 80 GB Teardown: 12 단계, 이미지 1/3 Zune 80 GB Teardown: 12 단계, 이미지 2/3 Zune 80 GB Teardown: 12 단계, 이미지 3/3
    • Remove the battery from the device with the cables still connected.
    • Carefully lift up the logic board located at the base of the Zune.
    • Unclip the orange ribbon cable in the same manner as in the previous steps.
    • Remove the logic board from the Zune, leaving the black wire connected.
  13. Zune 80 GB Teardown: 13 단계, 이미지 1/2 Zune 80 GB Teardown: 13 단계, 이미지 2/2
    • Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
    • The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
    • Remove the assembly and the battery together as one unit.
  14. Zune 80 GB Teardown: 14 단계, 이미지 1/2 Zune 80 GB Teardown: 14 단계, 이미지 2/2
    • Gently pry the screen unit from the black, plastic front frame.
koolkid
회원 가입일: 10/28/09
499 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 회원
CPSU-MANESS-F09S6G5
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
you can do the same with Zune 120, 4, 8 and 16
PROHIBIDO EL PASO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 44
전체 시간: 15,996
