주요 콘텐츠로 건너뛰기
Zune Flash 2nd Generation Back Cover Replacement
필요한 것
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Zune Flash 2nd Generation Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Back Cover Replacement: 4 단계, 이미지 3개 중 1개 Zune Flash 2nd Generation Back Cover Replacement: 4 단계, 이미지 3개 중 2개 Zune Flash 2nd Generation Back Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Back Cover Replacement: 5 단계, 이미지 3개 중 1개 Zune Flash 2nd Generation Back Cover Replacement: 5 단계, 이미지 3개 중 2개 Zune Flash 2nd Generation Back Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
결론
작성자
7다른 기여자 명과 함께
ybahman
회원 가입일: 11/01/09
139 평판
안내서 4개를 작성함
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 회원
CPSU-REGAN-F09S9G20
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 3,939
