이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide shows you how to replace the Zune Flash 2nd Generation face plate.
필요한 것
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
다른 2명이 해당 안내서를 완성하였습니다.
