소개
in this guide we will replace a broken lcd cable.
we will also see how to open the laptop , so you can replace other parts..
if you want to replace a broken screen , start at step 17 -18
필요한 것
now we will loosen the cable's from the main board.
remove the DC jack cable connected to the connector on the main board.
in the picture you see me using a IC axtractor, but i don't recommend it when you are not used to repair laptops...
when you are dealing with an broken DC jack , remove the whole cable ( black and red) running trough the plastic frame of the laptop...
remove the white big flat ribbon cable attached to the USB ( on the right) PCB.
again be careful and use a flat head screwdriver or a spudger to lift up the lever..
remove the audio cable from the connector , be careful if you tear the cables , you will have audio problems and there is a possibility that you will have BSOD ( blue screen of death) ...
remove the FAN cable from the connector , be very carefull because it are very tiny and breakeble cables...
remove the 3 screws seen in picture 1
remove 1 screw on the left side from the LCD connector.
after that, you can slide the main board out. ( lift it up on the right side, then slide to the right and take it out. )
when you want to remove the fan as well ( or replace it) you have to remove 3 screws, see picture 3
after removing the main board you have a view of the henges from the screen.
in picture 2 you will see the main board. , you can clean and or replace the CPU now.
to replace a cpu or clean the pads you will have to remove the screws seen in picture 3 .
clean the pads with isopropyl alcohol and always renew the CPU thermal paste . ( one drop on each spot is enough)
다른 한 분이 해당 안내서를 완성하였습니다.
