주요 콘텐츠로 건너뛰기
asus zenpad 10 touchscreen Replacement
필요한 것
동영상 지침
결승점
다른 10명이 해당 안내서를 완성하였습니다.
ian mdx
회원 가입일: 06/30/16
8,968 평판
안내서 17개 작성하였습니다
댓글 9개
How much is a screen replacement? My kids recently cracked the screens on their tablets
Leslie Alt - 답글
Any idea if there is a difference between asus zenbook 10 series z300 and z301 when it comes to the touchscreen?
I cannot seem to find a replacement touchscreen/digitizer for the z301 series. The ones I find are for z300c, z300m, z300cnl etc etc and I’m not sure if they will work as a replacement on a z301 (model p028).
John Frings - 답글
Hello
Have you got an answer and a solution to solve your replacement of screen of your p028 model?
Thanks
vador jean claude -
i have this model and did a full lcd replacement. however the touch is not functioning correctly, up and down does left and right and left and right does up and down. Any help would be greatly appreciated. (ive made sure the model number was correct and the parts ordered were correct.
Louis Phelps - 답글
where can I buy the screen? i’d rather find a EU seller
thanks
Marsala - 답글
hello I have a problem after changing my screen as on the video I end up with a touch inverted when I click on the bottom left on the screen the tablet click on the top left
richard dechatre - 답글
This is not the correct guide for asus P001 Just an fyi
Tito Trevino - 답글
Yeah, I have the same issue. Up,down is swapped with left,right… Any ideas what is going on?
lukasz.korbasiewicz - 답글
This is not touchscreen replacement. This is LCD + Touchscreen
Jacob Kettler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 30
전체 시간: 26,492
