소개
Do you have a wheel or wheels that will not rotate? If you have made sure that the structural integrity of the wheel(s) is not the problem, then this guide can be used to replace any wheel motor. You will need Phillips #1 screwdriver.
필요한 것
Depress the tab on the side of the dustbin to disengage its latch. It is spring loaded and will partially pop out. Remove it from its housing.
Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
Remove the screw (9.9mm Phillips #1) inside the brush compartment.
Depress the tabs on the circuit plugs and lift them directly upward to remove:
The multicolored nine-wire circuit plug at the top edge of the board.
The red and black wire circuit plug directly next to it.
The seven white wire circuit plug on the bottom edge of the board.
The red, white, and black wire circuit plug on the bottom left corner of the board.
Unscrew the six screws (9.9 mm Phillips #1) securing the wheel cover.
Remove the wheel cover from the mainboard.
