주요 콘텐츠로 건너뛰기
bObsweep Robotic Vacuum Battery Replacement
필요한 것
동영상 개요
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: 1 단계, 이미지 1/3 bObsweep Robotic Vacuum Battery Replacement, Battery: 1 단계, 이미지 2/3 bObsweep Robotic Vacuum Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: 2 단계, 이미지 1/3 bObsweep Robotic Vacuum Battery Replacement: 2 단계, 이미지 2/3 bObsweep Robotic Vacuum Battery Replacement: 2 단계, 이미지 3/3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: 3 단계, 이미지 1/3 bObsweep Robotic Vacuum Battery Replacement: 3 단계, 이미지 2/3 bObsweep Robotic Vacuum Battery Replacement: 3 단계, 이미지 3/3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: 4 단계, 이미지 1/3 bObsweep Robotic Vacuum Battery Replacement: 4 단계, 이미지 2/3 bObsweep Robotic Vacuum Battery Replacement: 4 단계, 이미지 3/3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
결론
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
다른 한 분이 해당 안내서를 완성하였습니다.
Tatiana
회원 가입일: 06/28/14
737 평판
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,765
