필요한 것
I will be showing you how to look at the motherboard of a coin counter
the first step is to flip it to the back to see the little screws
the second step is to remove the batteries.
To remove the batteries you have to take the top screw off
the second picture will show you how i toke out the screw in order to take out the batteries.to be safe when i get to the motherboard
the third step is to take out the 3 little screws in which side of the circle
In total you should have 3 screws. make sure you don"t lose them in case you want to put it back together
The fourth step is to remove the othere crews from the motherboard. You need to remove the crews in order to take out the motherboard.
You have to have the 4 screws if your switch the motherboard to a other one.
The 5th step is the hardest part because you have to now remove the red and black wires from both sides so then you can see the motherboard.
Be very careful removing or pulling the wires because it can break the other wires which will not work anymore.
The last step is you got to the motherboard which was my goal. you could use the motherboard for other projects or just put it back for more a challenge.
My decisions was to put it back together, so then i can have more of a challenge. thank you for your time and i hoped this helped
