주요 콘텐츠로 건너뛰기
d.light Solar Lantern S2 Battery Replacement
필요한 것
  1. d.light Solar Lantern S2 Battery Replacement, Battery: 1 단계, 이미지 1/2 d.light Solar Lantern S2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: 2 단계, 이미지 1/3 d.light Solar Lantern S2 Battery Replacement: 2 단계, 이미지 2/3 d.light Solar Lantern S2 Battery Replacement: 2 단계, 이미지 3/3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: 3 단계, 이미지 1/3 d.light Solar Lantern S2 Battery Replacement: 3 단계, 이미지 2/3 d.light Solar Lantern S2 Battery Replacement: 3 단계, 이미지 3/3
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jeremiah Rhoades
회원 가입일: 11/07/17
435 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G3, Harley Fall 2017 IUPUI, Team S2-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 51
전체 시간: 2,055
