주요 콘텐츠로 건너뛰기
d.light Solar Lantern S2 Circuit Board Replacement
필요한 것
  1. d.light Solar Lantern S2 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/2 d.light Solar Lantern S2 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Circuit Board Replacement: 2 단계, 이미지 1/3 d.light Solar Lantern S2 Circuit Board Replacement: 2 단계, 이미지 2/3 d.light Solar Lantern S2 Circuit Board Replacement: 2 단계, 이미지 3/3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove battery by unplugging it from the circuit board.
  4. d.light Solar Lantern S2 Circuit Board Replacement: 4 단계, 이미지 1/2 d.light Solar Lantern S2 Circuit Board Replacement: 4 단계, 이미지 2/2
    • Remove the circuit board by pressing on the mounting clips (shown in red circles) using the spudger.
  5. d.light Solar Lantern S2 Circuit Board Replacement: 5 단계, 이미지 1/1
    • Desolder the wires to free the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeremiah Rhoades
회원 가입일: 11/07/17
435 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G3, Harley Fall 2017 IUPUI, Team S2-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 39
전체 시간: 1,289
