주요 콘텐츠로 건너뛰기
d.light Solar Lantern S2 Solar Panel Replacement
필요한 것
  1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: 1 단계, 이미지 1/2 d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: 1 단계, 이미지 2/2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Solar Panel Replacement: 2 단계, 이미지 1/2 d.light Solar Lantern S2 Solar Panel Replacement: 2 단계, 이미지 2/2
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Solar Panel Replacement: 3 단계, 이미지 1/2 d.light Solar Lantern S2 Solar Panel Replacement: 3 단계, 이미지 2/2
    • Desolder the yellow and black wires that connect the solar panel to the circuit board.
    • Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
  4. d.light Solar Lantern S2 Solar Panel Replacement: 4 단계, 이미지 1/2 d.light Solar Lantern S2 Solar Panel Replacement: 4 단계, 이미지 2/2
    • Solder the wires to the solar panel (positive to positive, negative to negative).
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremiah Rhoades
회원 가입일: 11/07/17
435 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G3, Harley Fall 2017 IUPUI, Team S2-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 632
