주요 콘텐츠로 건너뛰기
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
필요한 것
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: 1 단계, 이미지 1/2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: 1 단계, 이미지 2/2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 2 단계, 이미지 1/2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 2 단계, 이미지 2/2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 3 단계, 이미지 1/1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: 4 단계, 이미지 1/2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: 4 단계, 이미지 2/2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 5 단계, 이미지 1/1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 6 단계, 이미지 1/2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: 7 단계, 이미지 1/2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: 7 단계, 이미지 2/2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 8 단계, 이미지 1/1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 9 단계, 이미지 1/1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob
회원 가입일: 03/11/15
757 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 회원
UCCS-PANKO-S15S4G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 200
