주요 콘텐츠로 건너뛰기
eMac AirPort Card Replacement
필요한 것
  1. eMac AirPort Card Replacement, AirPort Card: 1 단계, 이미지 1개 중 1개
    • Installation of the AirPort Card on this machine is very easy.
    • The AirPort slot is located just above the Optical Drive in the front of the unit. It is covered by a small plastic panel.
  2. eMac AirPort Card Replacement: 2 단계, 이미지 2개 중 1개 eMac AirPort Card Replacement: 2 단계, 이미지 2개 중 2개
    • Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
    • Remove the two Phillips screws located to the right and left sides of the optical drive tray.
    • The Airport cable is snapped into place on the back of the optical drive panel .
    • Gently remove the panel from the front of the eMac
    • Disconnect the AirPort cable from the optical drive panel.
    • Pull the AirPort card straight away from its socket in the eMac.
  3. eMac AirPort Card Replacement: 3 단계, 이미지 2개 중 1개 eMac AirPort Card Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the new AirPort card into the slot until its firmly seated.
    • Reconnect the AirPort cable to the optical drive panel.
    • Reattach the optical drive panel and restart the eMac.
    • To configure the AirPort card, go under the Apple in the upper left hand corner to System Preferences - Network. The AirPort option should be on the left hand window. Select it.
    • It should set up on its own. If not hit the "Assist Me" box on the bottom of the page.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
mayer
회원 가입일: 01/04/10
689,162 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 83
전체 시간: 27,664
