주요 콘텐츠로 건너뛰기
소개
This machine uses the:
Apple 630-2883 Original APPLE-MAC Airport 802.11B Wireless Card from the 700 MHz machine through the eMac (ATI Graphics). After that it uses the Apple M8881LL/A AirPort Extreme Card.
부품
지정된 부품이 없습니다.
  1. Installation of the AirPort Card on this machine is very easy.
    • Installation of the AirPort Card on this machine is very easy.
    • The AirPort slot is located just above the Optical Drive in the front of the unit. It is covered by a small plastic panel.
  2. Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine. Remove the two Phillips screws located to the right and left sides of the optical drive tray.
    • Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
    • Remove the two Phillips screws located to the right and left sides of the optical drive tray.
    • The Airport cable is snapped into place on the back of the optical drive panel .
    • Gently remove the panel from the front of the eMac
    • Disconnect the AirPort cable from the optical drive panel.
    • Pull the AirPort card straight away from its socket in the eMac.
  3. Slide the new AirPort card into the slot until its firmly seated. Reconnect the AirPort cable to the optical drive panel.
    • Slide the new AirPort card into the slot until its firmly seated.
    • Reconnect the AirPort cable to the optical drive panel.
    • Reattach the optical drive panel and restart the eMac.
    • To configure the AirPort card, go under the Apple in the upper left hand corner to System Preferences - Network. The AirPort option should be on the left hand window. Select it.
    • It should set up on its own. If not hit the "Assist Me" box on the bottom of the page.
결론
다른 16명이 해당 안내서를 완성하였습니다.
mayer
회원 가입일: 2010년 01월 04일
653,645 평판
안내서 12개 작성하였습니다
MacHale Enterprises MacHale Enterprises 회원
Business
1 회원
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 36
전체 시간: 25,089
