이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
Remove the two Phillips screws located to the right and left sides of the optical drive tray.
Gently remove the panel from the front of the eMac
Disconnect the AirPort cable from the optical drive panel.
Pull the AirPort card straight away from its socket in the eMac.
Slide the new AirPort card into the slot until its firmly seated.
Reconnect the AirPort cable to the optical drive panel.
Reattach the optical drive panel and restart the eMac.
다른 19명이 해당 안내서를 완성하였습니다.
