주요 콘텐츠로 건너뛰기
eMac Fan Assembly Replacement
필요한 것
  1. eMac Fan Assembly Replacement, Door Removal: 1 단계, 이미지 1/3 eMac Fan Assembly Replacement, Door Removal: 1 단계, 이미지 2/3 eMac Fan Assembly Replacement, Door Removal: 1 단계, 이미지 3/3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Fan Assembly Replacement, Bottom Screw Removal: 2 단계, 이미지 1/1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Fan Assembly Replacement, Top and Side Screws: 3 단계, 이미지 1/3 eMac Fan Assembly Replacement, Top and Side Screws: 3 단계, 이미지 2/3 eMac Fan Assembly Replacement, Top and Side Screws: 3 단계, 이미지 3/3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Fan Assembly Replacement, Power Button Cable: 4 단계, 이미지 1/2 eMac Fan Assembly Replacement, Power Button Cable: 4 단계, 이미지 2/2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Fan Assembly Replacement, Shell Removal: 5 단계, 이미지 1/1
    • Now the entire shell can be removed from the computer.
  6. eMac Fan Assembly Replacement, Panel Removal: 6 단계, 이미지 1/3 eMac Fan Assembly Replacement, Panel Removal: 6 단계, 이미지 2/3 eMac Fan Assembly Replacement, Panel Removal: 6 단계, 이미지 3/3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. eMac Fan Assembly Replacement, Cables: 7 단계, 이미지 1/3 eMac Fan Assembly Replacement, Cables: 7 단계, 이미지 2/3 eMac Fan Assembly Replacement, Cables: 7 단계, 이미지 3/3
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
  8. eMac Fan Assembly Replacement, Screws: 8 단계, 이미지 1/2 eMac Fan Assembly Replacement, Screws: 8 단계, 이미지 2/2
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
  9. eMac Fan Assembly Replacement: 9 단계, 이미지 1/1
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
  10. eMac Fan Assembly Replacement, Assembly Removal: 10 단계, 이미지 1/2 eMac Fan Assembly Replacement, Assembly Removal: 10 단계, 이미지 2/2
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chris Green
회원 가입일: 10/11/09
36,978 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
Does anyone know the names of connectors for the fan? I would like to power one externally if possible.
grantdavis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 1,192
