주요 콘텐츠로 건너뛰기
iPad 6 Teardown
6 단계
iPad 6 Teardown: 0 단계, 이미지 3개 중 1개 iPad 6 Teardown: 0 단계, 이미지 3개 중 2개 iPad 6 Teardown: 0 단계, 이미지 3개 중 3개
  • With the display out of the way, we can safely disconnect the digitizer.
  • The digitizer has the same two cables as before, but they look a little different than last year.
  • Could they have changed slightly for Pencil compatibility?
  • Look what we found hiding under a shield! The same NXP 8461A1 Touch ID chip that we saw in the last model.
  • Our wallpaper images for iDevices have been exceedingly popular—there's no denying Apple makes some gorgeous internals. If you wanted some wallpaper to educate you about your iPad's components, we've got you covered!
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
