주요 콘텐츠로 건너뛰기
도움말
5단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 3개에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
Lift the home button bracket starting from the left side.
Carefully pull it upwards toward the display, making sure not to damage the home button cable.
During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
Secure the bracket with a high bond glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
It may be necessary to use vise clamps to hold the home button bracket in place as the adhesive cures.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
