주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
10단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 5개에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
Reapply the piece of tape covering the AirPort & iSight data cable socket.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
