Help
2단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 2개에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
Before you start placing strips, remove all of the old adhesive from around the perimeter of the rear enclosure.
If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
After all the old adhesive is removed, carefully clean the area under the adhesive with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
