주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
29단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 48개에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
You can try these alternate removal methods to reduce your chance of cracking the LCD during the removal process:
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
