주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
7단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Carefully turn the daughterboard over, making sure to not tear the attached cable.
Pull the IR Sensor cable straight away from its socket on the board.
Be sure that you are not pulling on the cables as you remove the plug from its socket.
Blu-Ray drive remains.
If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
