주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
3단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Repeat for the second strip.
Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
If you removed both adhesive strips successfully, skip to step 27.
If either of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
Do not insert the spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath. Do not pry against the logic board or you may damage the phone.
For alternative methods to unstick the battery, continue with the next step below.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
