주요 콘텐츠로 건너뛰기
Hp Pavilion dv6-2155dx USB Port Replacement
8 단계
Hp Pavilion dv6-2155dx USB Port Replacement: 0 단계, 이미지 2개 중 1개 Hp Pavilion dv6-2155dx USB Port Replacement: 0 단계, 이미지 2개 중 2개
  • Disconnect the power connector cable by using the point of the plastic spudger. continue to slide the plastic part until it is completely removed or you are able to grab the plastic with your fingers.
  • It is not advised to pull the cable bundle to remove this. By doing that you can damage the small wires that are connected.
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
